Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
touch id doesn't work after battery replacement
replaced the battery. no problems. afterwards, though, as soon as the phone starts, says it can't enable touch ID. when i try to enable it in settings, i get an immediate failure. double tap also doesn't work to bring the screen down. otherwise phone working fine.
Score 2
2 Comments
force touch works. took it to a ubreakifix store and tried replacing entire screen - didn't work. visually inspected the cables and motherboard - no damage.
by
Paul, probably something on the board is damaged because of corrosion or there could be a short circuit. Disassemble device, clean board of any corrosion, with magnifying glass also check all solder joints for being,poor, cracked, burnt.
by
Add a comment
Chosen Solution
Paul, You may have to try a hard reset to completely wipe your iPhone and set it up like new, before doing this check the link below for common touch ID problems and fixes.
Check the attached link,instruction and guide, Good luck
http://www.gottabemobile.com/2016/05/27/...
Score 2
2 Comments:
didnt work. immediately touch id failed.
by
Erasing your data is called a soft reset, not a hard reset. :)
by
Add a comment
Typically with a battery install you don't need to mess with the home button. If you removed the screen completely you might want to check the home button extension flex that connects to the logic board. Make sure it's seated properly. Also, verify that the extension flex connector and logic board connection look good...
Is force touch working?
Let's hope it's just a connection issue...
1 Comment:
by
Add a comment
Add your answer
paul foster will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 5,968
