won't start,new battery and solenoid.
Golf Cart yamaha g16 gas new battery and solenoid. will start if solenoid is jumped. I have checked all fuses. any suggestions help.
Leonard, If battery and solenoid known to be good, look in black box right behind the battery, take the cover off locate the 10 amp fuse and replace it if blown. If equipped with safety features like seat switch, safety neutral, etc. check/test that they are functioning properly. If all looks good there check wires and plug on ignition switch and test switch for proper function.
Hope this is of help. Good luck.
@mezkin check to make sure your fuse (#34) has continuity and that your main switch (#30) works. Use a jumper to find out if you can "hot wire" it. If that works, replace that assembly.
I have a G16 new coil , fuel pump cleaned carb have spark and fule but it still starts hard . So I disconnected the kill switch to coil to go around any electrical circuits. Adjusted valves to .004 with no luck ! What are the chances I sheared the key way on the flywheel? It was dieing and backfiring I have 160 compression so I'm at s loss please help
Thank you. It was the 15AMP fuse. Thanks again John
Yamaha g16 gas it runs for about blocks and dies . You have to let it set for awhile before it starts again like 45min can anyone help me
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 131
All Time: 46,362
5 Comments
@mezkin it will start every time you apply a jumper to the solenoid?
by oldturkey03
We have the same problem. Brand new battery and solenoid. Can jump solenoid. When key is on lights work and in reverse position beeps but when you push on petal nothing happens.
by ctrryb
97 Club Car will not start good solenoid good battery cannot jump it what could be the problem
by Domingo Ordonia
1997 club car gas golf cart has new battery new solenoid will not turn over if I jump the solenoid still will not turn over
by Domingo Ordonia
2013 ez go w/Kawasaki 400cc engine. Just quit one day. Brand new solenoid and battery. Solenoid chatters, starter turns but won’t start the motor. Once in a while I’ll get a little bump where it wants to start but just won’t. I’m thinking it’s the starter/gen…
by Patrick rahbine
