Why the mower deck won't turn
when I engage the mower deck it will not turn the blade is this because the belt needs replace
BK. there can be a few things for blades on a riding mower to not turn, broken deck clutch cable, broken/worn belt, belt has slipped off pulley, seized pivot arm, belt not routed properly, if blades are electric clutch driven, could be a fuse, bad wire broken/connection, faulty clutch, faulty engage switch,faulty battery, etc.
You may want to have a good small engine tech. have a look, diagnose and estimate repair.
Check the attached links for more detail on how to check for a lot of stated possible faults.
http://www.shopyourway.com/questions/116...
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 70
All Time: 5,940
1 Comment
bktrouble2001 could very well be the belt. What model is it and what have you checked?
by oldturkey03
