Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Location of Bluetooth Card?
Where is the Bluetooth card located in a Glossy Screen 2009 MacBook Pro ?
Is it located with the WiFi card ?
Update (09/05/2016)
WiFi Card blown by Bit Torrent large download. Unfortunately Replacement S/H Card from USA. has a faulty Bluetooth section, on external test.
Hence the enquiry to confirm that Both are on the One Card & Not Elsewhere.
3 Comments
Apple has three different models here. Can you give us the exact model info. Plug in your full serial number here: EveryMac Lookup. Then paste the systems URL into your question so we can isolate which system you have.
by
Make sure you got the correct part here. If you got the antiglare version of the Airport board you got the WiFi only version.
by
Add a comment
Chosen Solution
There are three models in the year of 2009, the late 2008-2009 had it as part of the wifi (airport) card, the other two had them here in this guide;
MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement
NOTE: the glossy and the anti glare models had them in different places so if you gave the glossy one make sure you press the button showing ware it is.
Score 1
Add a comment
Most Helpful Answer
As you have the Glossy display you have a combo card (WiFi/Bluetooth) which is located within the Clutch cover. Here is the correct teardown for it: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement
Score 2
1 Comment:
Thanks, Dan. Just have to wait on PowerBook Medic for aTested Replacement or a New Card. (In Process at Present).
by
Add a comment
Add your answer
Douglas G Allen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 767
