iPad 2 Power, volume buttons do not work after ribbon replacement
so i was trying to fix an ipad2 with cracked screen, after digitizer replacement the power button would not work. so i heard the power ribbon cable could be damaged. i replaced the ribbon cable twice with 2 different cables but power/volume buttons just will not work. any one have any idea?
these are quite hard to replace without damaging the new flex, so inspect to see if you can see any damage and if not try plugging in a new flex (without installing) and see if it works. if not the inspect the flex connector on the board to see if theres any corrosion or debris stuck. good luck
by Hortman
I just noticed that the part of the flex that connects to the board under the camera is missing The plastic clip that locks it in place, the cable is stil sitting in place but without the lock is it not making a proper connection? Could this be my problem?
by adrian collins
