Washer is powered up but won't spin or agitate
I have a GE WJRR4170G0WW washer that stopped working. It pumps water out and I can hear the timer working but it will not agitate or spin. Even when manually turning the timer dial. I bypassed the lid switch (hoping that it would be an easy fix) with no luck. Also inspected the drive belt and it looks great.
1 Comment
Richard Howell how did you bypass the switch? Have you checked the motor to see that it gets power and is working?
by
Add a comment
1 Answer
Chosen Solution
Richard Howell if you properly bypassed ( or diagnosed) the lid switch as functioning properly, and the belt is okay, you will have to checked the motor. Make sure that it has power first.
Score 1
Add a comment
Add your answer
Richard Howell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 249
