Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
I am trying to replace digitizer, cant get suction cup to stick
My glass is really smashed, when I put the suction cup on it, I cant get a seal to pull it off, any suggestions???
Score -1
Add a comment
Chosen Solution
Put sticky back plastic/ contact? Sellotape, duct tape. Anything like that over the broken glass. Make sure it's not bonded to the bezel. Hey presto-
Score 2
Add a comment
the suction cup most likely won't seal. you can take a very fine tip flat head precision screwdriver and wedge it between the rubber gasket and the metal bezel down by the home button. pry up gently, try not to damage the gasket. also be careful of the electronics on the dock assembly and the home button ribbon.
Add a comment
Add your answer
Cathy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,291
