TV does not power on, but I see a blue light.
Ok so the Samsung PN50A530S2F TV is plugged in and I see a blue light yet when I attempt to power on the TV there is no blue light, sound, or picture. Is this repairable? Thanks in advance!
7 Comments
rcmashop where do you see the blue light? If you can, unplug your set and remove the back. take some pictures of the board arrangement and the boards itself. Post those with your question. that will help us to see what you see. It is possible that this could be fixed by repalcing/repairing the power board. To add images use this guide Adding images to an existing question
Also, can you double check your model number? It does not show up in my manuals at all. Is it possible that your model is a PN50A530S2F?
by oldturkey03
the blue light is the stand by light. also you were correct as to the model number being PN50A530S2F. I just check the main board and the RLY802, RTE801, and RTE802 are burnt. should i change the whole board?
by rcmashop
can you see it? do i change the whole board?
[image|875833]
by rcmashop
may be not. Can you zoom out of this and give us a view of the whole board. Just trying to see if it is just those capse or if anything else happened. Do you have access to soldering equipment and are you handy enough to do a repair?
by oldturkey03
ok here is a zoomed out pic. yes i have a soldering kit and im confident lol. thank you
[image|875857][image|875858]
by rcmashop
Show 2 more comments
