Replaced motherboard, heatsink doesn't match
We tried replacing a motherboard on a MacBook Pro 13" Unibody Late 2011 with the i5 CPU. We put in a motherboard with the i7 2.8GHz. When we got it, there are capacitors actually in a different place so the heat sink doesn't match. According to the iFixIt site, all Late 2011's should use the same heatsink - this one.
That said, the motherboard we bought (this one) doesn't match. Any thoughts? Is this not really a late 2011 motherboard?
If you notice, the two capacitors directly above the CPU are in the way of the standard heatsink.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Heat Sink Image
Product
$17.99
Add a comment
1 Answer
FYI, the one I found on eBay worked fine. Part numbers are the same so I'm not sure how one tells the difference.
Add a comment
Add your answer
Scott Behrends will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
