Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
I removed screen and replaced now wont switch on,all cables on
iphone wont switch back on after repair?
Add a comment
1 Answer
Chosen Solution
Try reseting your phone. Open it up and disconnect the battery. Remove all the screws from the logic board and lift it up (it is held down onto the battery by contacts, when you lift it becomes disconnected). Then attach your LCD and turn your phone on.
It is safe to turn on the phone with the display assembly not clipped in. This is helpful while debugging, so that you don't have to pull out the suction cup each time to change something.
Add a comment
Add your answer
bryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 621
