Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4262 Questions View all
Camera wont take pictures.
My iphone 6 camera wont take pictures I can open up the camera app and see that the camera is working but when i click to take a picture it does the normal picture taking animation but nothing is saved, its very weird because when i switch to video mode the camera can take a video and save it like normal, any ideas of whats wrong or what part i should replace thanks
Score 1
Comments:
I replaced the camera and still the same problem also flash isnt working
by
Add a comment
This doesn't require replacing anything, because you said it takes videos. Have you done a hard reset? Hold power button and home button until phone restarts
Comments:
Just tried that it didnt work and I also noticed I can take panoramas and they save but snapchat doesnt take pictures only video
by
What version of IOS are you running?
by
I'm running the most recent version 9.3.3 I think it is
by
I would try updating the phone through the computer, most times when updated over the phone it can be a bit buggy
by
The flash also doesn't work
by
Show 1 more comment
Add a comment
same problem here. no solution
Add a comment
I was told I need to have front and back camera replaced. When guy tested camera he said nothing wrong with cameras, what else can be the problem pls?
Comments:
It worked!!!!!!!! Thanks!!!!
by
What worked ?????????
by
Powering off and back on worked for me with this same problem.
by
Add a comment
in my situation , both camera were not work , after change camera ic U2301 , all thing go ok , but photo not saved , the fix was so simple and easy , just change your time zone then back it to auto set from time setting , and thats all , camera now saved photo normally .
Add a comment
Add your answer
Jeffrey claro will be eternally grateful.
Past 24 Hours: 38
Past 7 Days: 238
Past 30 Days: 964
All Time: 8,450
