Repair guides and support for your Samsung TV.
2620 Questions View all
My Samsung TV Won't Stay On. Tried Factory Reset.
Hello!
My Samsung TV Model: UN55D6000SFXZA will not stay on. It will turn on for about 30 seconds, then turns off. I found the code to access the tech menu and I tried factory reset, however, that doesn't work.
I have tried to change HDMI cables, switched from HDMI to traditional cables, called the cable company to check the box, nothing. I have tried to use a different electrical outlet, just in case. It's the TV.
Note: It does NOT turn itself off and on - just off after about 30 seconds
Any thoughts? Thanks!!!
3 Comments
@dree do you have to wait to turn it back on or does it turn on again right away?
by
@oldturkey03 I can turn it back on immediately.
I try to press source or menu in the 30 seconds it's on, and it turns off anyway.
Thanks!
by
My TV changes Source everytime I turn it off it goes back to cable
by
Add a comment
Most Helpful Answer
@dree try to follow the trouble shotting flowchart first. I would suspect the power board to have issues. It sounds like your TV goes into a self protect mode. Post a couple of picture of the back of your TV to see how the boards are arranged and a few of the boards itself. That way we can see what you see. Use this guide for that.
Score 1
Add a comment
Had to resolder the transformer on the power supply. See attached picture for location of poor solder connections. You can see the solder but it was broke away and would loose connection
Score 1
Add a comment
Add your answer
Dree will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 3,560
