Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iTunes won't detect iPhone
Hi Everyone,
My phone is stuck on the apple logo. I could only get it to restore, but iTunes won't detect. My lightning cable work. I assume my dock connector works as well since I got it to restore mode. Any Ideas?
4 Comments:
Is your lighting cable an apple product? If it is a no-name brand that might be your issue.
by
Did you try DFU (Device Firmware Upgrade) mode yet?
by
Yes i am using the original Lightning cable that came with. I can't get it to go on DFU mode. I could only get to restore. When I am on restore mode I can't get it to detect on iTunes
by
How many drives do you have on your PC. I have too many and sometimes Windows 10 will not detect anymore drives when I connect more on my system. If you have alot try disconnecting any external drives off you system and then try again. If you are using an apple computer please disregard.
by
Add a comment
1 Answer
Just because the phone says it's connected by the lightning cable doesn't mean it actually is. I had an iPhone 4s with a similar issue as yours. It ended up being caused by a damaged diode on the mother board.
Add a comment
Add your answer
Eliel Arredondo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 127
