The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Questions View all
Replacing screen, can I reinforce ribbon cable with Kapton tape?
A couple months back I dropped my M8 from shopping-cart height onto the hard store floor. It fell flat on its face (no corner impact), and I was ecstatic to pick it up unharmed -- yay case! But, a couple weeks later, the screen began to warp up, indicating the battery was beginning to bloat, so, not undamaged after all.
By the time the replacement battery arrived, the bloat was fairly significant, and, despite following the teardown instructions carefully (especially where it said "be careful, we tore the ribbon cable so you don't have to"), I still managed to tear the tiny, 1/4"-wide, tissue-paper- thin section of ribbon connecting the screen.
The replacement is due to arrive in a few days, and I'm wondering whether any harm can come from reinforcing this section of ribbon, so any future work would be less likely to cause damage? I'm thinking of sandwiching the ribbon between two layers of the Kapton tape -- good? bad?
As a secondary question, is there any way to verify the screen I receive is genuine Gorilla glass? Any markings to look for? any discreet non-damaging tests?
Also, my original screen is undamaged, is it feasible to only switch out the ribbon and keep my screen? or is that hardwired and impossible?
Thanks very much!
Add a comment
1 Answer
Most Helpful Answer
I hope i understood your question right!
Well i have an i5 ,and i have a lot of confidence about repairing my device , so i take it apart for small problems by my self ...anyways...
I was thinking like you and ive done that on my ribben cable (flex cable) of lcd + touch cable
Lcd cable is tough (hard ) and touch is soft very soft
Lcd cables is already sandwiched btw two copper surfaces that prevent noice in the picture, and if you want the truth...tape didnt save my lcd cable from seprating :/ flex cable has a crack in the center now and theres no picture.... So tape methud doesnt work on lcd andddd touch cable as i said is. very soft and flexible that does not need extra protection (unless you cut it somehow).
I cant answer your second question cause i dont know about geniue parts (honestly i dont think its gorilla acually maybe a good glass ,if it was second handed yep)
Score 1
1 Comment:
Thanks for your reply. The cable had two sections, one fairly wide, and, as you say, fairly tough, and the other only about 1/4" wide and very, very delicate: I didn't cut it, it simply tore with very little assistance on my part -- I'm guessing the pressure of the bloated battery helped in that. Once it was torn, the screen would no longer come on, so I'm not sure where this fits into your LCD/touch cable description.
In any case, thanks very much for taking the time to reply. :O)
by
Add a comment
Add your answer
MorWired will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 738
