The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Questions View all
Laptop won't turn on.
Plug the charger in and no charging lights come on. Power button makes a clicking sound when pressed. New after market charger. Battery reads 3.2 when tested on ohms meter. What is the problem? Also, looked at ram and it say 2GB. I thought this model was minimum of 4GB.
Add a comment
1 Answer
The fact you don't even get a charging light could mean that the charge port or power board is faulty.
It's tricky to diagnose without a good root around but my next guess would be the CMOS battery could be dead.
If replacing that didn't sort it I'd look to the RAM. Faulty RAM would stop the BIOS/CMOS from even starting, but then again I think you'd still get a power light.
Add a comment
Add your answer
John Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 502
