Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Questions View all
Smart cover sensors (Hall Effect) too sensitive after new digitizer
Hello,
So I have replace the digitizer on two different iPads now, and both have exhibited the same behavior. After replacement the Apple smart cover now affects the sleep/awake sensors from the BACK of the iPad. So when you fully flip back the cover, it will actually shut the iPad OFF. Both of these iPads used a smart cover before the repair with no issues. The first one I did, I wasn't able to troubleshoot as the adhesive was already in place before we discovered the issue. But for the second one, I left it "apart" with the new screen to test.
Oddly, even if I fully disconnect the new digitizer, and put it far away, the smart cover still shuts the iPad off and on from the back. So that tell me that it has nothing to do with the new digitizer. So I then took two magnets, and tried to play with the sensors. Reading many articles, it appears that the Air 1 requires TWO magnets to be in place for the awake/sleep functions to work. However, in my case, I only need to use ONE magnet over the right-most trigger point to make the iPad turn on/off. It's like the one next to the home button doesn't do anything anymore (or more accurately, constantly sees a field). Any ideas what is causing this? I was thinking heat (from removing the glass), but these components are pretty deep in.
Any thoughts?
Add a comment
Chosen Solution
Hello all!
So after playing around much more, and running across this post (Smart Cover Locks iPad Air from Back Side) it seemed that the home button flex cable might be causing the issue. I had my strong doubts since the circuitry on both cables LOOKED (to the naked eye) identical. But to test, I used the button off the old glass, and it worked PERFECT! While there doesn't seem to be any magnets in that cable, there must be some type of logic circuit in there relating to the awake/sleep switch. I have to say, I'm pretty disappointed in ifixit's parts (not their instructions) because of this. I lost so many hours. If a button (or cable) doesn't have full functionality - that's fine... we just need to know!
Thanks,
Bill Bushong
Score 1
Add a comment
Most Helpful Answer
If I'm correct the original digitizer + glass comes with the metal piece for these magnets. The one that originally came with the iPad. If it's there on there you should be able to extract them from there and put it on the new glass you have.
Score 1
Add a comment
problem lies in home btn flex cable
Score 1
1 Comment:
sometime cover will not help you will need change, i suggest always transfer original
by
Add a comment
actually, the digitizer is most definitely the issue. u may change the source u got the digitizers from. magnets have less effects on good digitizer as I've experienced. another thing is an exposed part of the home button flex, that causes malfunctions always
Add a comment
Add your answer
bbushong will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 5,464
