Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Partial startup but won't boot
I recently replaced the battery on my Macbook Pro.
Unfortunately I fried L7602 which is a ferrite in the ground/case leg of the microphone by shorting it to the battery (mea culpa)
The system now boots in the following way:
1. Fan starts - low speed. SIL light is bright white. Power cable has green light.
2. SIL light flashes 5 times, goes out.
3. Fans go to high speed, DVD cycles, screen backlight turns on.
Tests
  1. All power supply voltages check OK - ALL_SYS_PWRGD is OK
  2. MCP_PS_PWRGD, FSB_CPURST_L and CPU_PWRGD are OK
  3. CAPS Lock LED on Kbd doesn't work
  4. Power button turns system off after 5s
  5. Power + (ShftCtlOpt) turns power off immediately, so Kbd is being sensed
  6. Removing system RAM gives 5 flashes followed by one repeating beep, so diags are working
Any thoughts?
Add a comment
Chosen Solution
The final answer was very simple -
Re-instal the trackpad.
Who knew - a Macbook Pro won't boot without the trackpad installed, not even to diagnostics.
Oh well, I know a lot more about Landrex, TLink, and Macbook Pro operation. Live and learn :)
Add a comment
You say “SIL light flashes 5 times, goes out.” try looking more info about this over the WEB maybe this is a error code that tells you the problem.
1 Comment:
The web comments relating to 5 flashes are a bit confusing.
From what I can see the five quick flashes at the start are undocumented. I think the SIL flash codes are slower. If I remove the RAM I get one slow flash code and one beep - the correct diagnostic for "No RAM".
I suspect if I could force the CPU error, I would get five slow flashes accompanied by five beeps.
Apple suggests -To start Apple Diagnostics:
Turn off your computer if it is on by choosing Shut Down from the Apple () menu.
Press the power button to turn on your computer.
Immediately press and hold the D key until Apple Diagnostics begins.
But this didn't help.
by
Add a comment
Add your answer
ozarchie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 181
