No Sound except for headphones. Very Bad Network Reception, weak Wifi
Hello to all
I have a real curly one this week
My N7105. I decided to get the S5, so did. Decided to sell the N7105
But had it for a couple of years with no problems but normal thing, was looking tired
Replaced the mid frame
Charge port flex (Original Part)
New Battery
Did not do anything with the phone for a few months, just lived in the office
Other day got it out the draw and decided to sell it so checked it and found that the wifi reception was weak, there was no sound unless you used head phones
Phone is unlocked as I originally bought it outright but always with the same courier
Tried it on another courier and worked, The one with the strongest signal in this area but the signal was weak so put the old sim in, the one in my present phone. Signal was weak too, Charged beautifully
Then had a break on that and checked the Sound. Nothing! ugged in the headphone, works great. So did the plug in and out trick, no did not work. Hard Reset did not work . All settings in phone are OK
Also got the Circle with the bar through it up where the signal usually is. Checked the settings, not checked
Charge port flex connector looks OK
''Could the flex cable be responsible for all of this??'"""""
My nails are getting shorter
Recap:
Weak Signal,
No Sound except with Headphones
Weak Wifi Signal
Score 2
Add a comment
1 Answer
Chosen Solution
When you mean by Charge port flex (Original Part) did you buy the exact same model number one? Because if you buy a slightly different one it can cause all these issues.
Score 2
1 Comment:
Hi Ben that is great thank you for your answer. I'll order in the real Original one and see how it goes.
by
Add a comment
Add your answer
Charlie Clemett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 198
