Laptop made some loud clicking sounds and the computer slowed down.
My laptop sustained some sort of damage near the hard drive. It clicked for a bit then stopped, the computer became slow so I checked task manager and the disk was almost at 100% whenever I tried to access information. I shut it off and restarted it. It began to auto repair itself. I had too leave though so I left it alone.
Add a comment
Chosen Solution
Does the computer OS work and it only shuts down when you try to open a file? This does defiantly sound like a failing hard drive and I would not waste time trying to repair it use whatever life is left on the hard drive to move your important data. pick and choose only whats important dont try to clone it it probably wont survive that long . I really hope you had your data backed up. Repairing the hard drive is a long and difficult procedure it is also very expensive if you need to have it done .
Score 2
Add a comment
Most Helpful Answer
This typical hard drive clicking noise means that the System Area (SA) cannot be read. It could be simple or complex to fix.
The System Area is located on the magnetic platters of your hard drive. It is typically on the outside cylinder for a 3.5? hard drive and on the inside cylinder for a 2.5?. This is a very complex area. It is knows as well as Maintenance track, Negative cylinder, Reserved cylinder, Calibration or Initilization area or even Disk ware.
The reason of hard drive making clicking noise because we know the SA cannot be read. You can have 4 main reasons (and a possible combination of them) for this to happen:
Heads are dead
Preamplificator is dead
SA corrupted or scratched
Firmware on the PCB
Whatever you do, you will need to repair the hard drive first.
For heads and preamplificator…well you only have a choice which is to swap the head of your drive. This is where it gets expensive in terms of data recovery services. Head swapping should be done in a white room, but if you are skilled enough you can try it in a clean environnement if you don't plan to spend money anyway on your data. Head issue is very common if you dropped your external
hard drive.
If the SA is scratched you might have a shot through a live pcb swap. It will basically bypass the reading of the SA and you have a cheap shot at getting your data back.
It all depends on what data you need to recover. If it's critical data then I would recommend Gilware.com for data recovery.
Score 2
Add a comment
Add your answer
Red Fox will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 932
