Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Questions View all
Why is my front right Indicator not working,bulb ok
I have a XL1200 Harley Davidson Sportster 2012
It came on yesterday 9/6/2016 as i was turning right,then suddenly went out and on dashboard little green arrow flashing rapid?
Add a comment
Chosen Solution
Check the rear bulb as well when one goes the other acts weird so check to see if the rear bulb is bad
Score 2
1 Comment:
Thanks Jim i will check rear indicator just in case that is the fault.:)
by
Add a comment
Most Helpful Answer
Sam "little green arrow flashing rapid" is caused by the indicator not working. Make sure that the bulb is indeed okay, I'd replace it anyway. If a new bulb is not working as well, check the wiring going to the indicator. Make sure that it shows continuity.
Score 2
1 Comment:
Funny enough the indicator decided to work in the rain,touch wood its still working now,but i will check back indicator like you said,thanks oldturkey :)
by
Add a comment
Add your answer
SMUDGER will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 16
All Time: 1,561
