Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Powers on, screen does not work, is the logic board damaged?
I have an iPhone 6 which had a working lcd display but the digitizer was failing on it so I performed a screen replacement (install new lcd + digitizer assembly) which I have done many many times on this model iphone. I took the screen off and transferred everything to the new screen and reconnected the battery then before snapping the phone back together (I did not reinstall the shield plate over the ribbon cables yet) I plugged the phone into a charger. The device powered on because I could hear it vibrate to indicate charging but the display never came on. I cannot figure what is wrong.
Things I have tried already:
-two different brand new screens
-with and without the camera flex
-two different lcd Shields
-used magnifying glass to inspect all connections on the logic board, everything looks good
-this is not long screw damage because I never reinstalled the screws on the board
-power cycled the device
-with and without the home button
-there's no water damage
Does anyone know what is wrong??
Add a comment
1 Answer
Most Helpful Answer
Try testing the original LCD on the phone and see if you get a display, just to rule out the possibility of having gotten two bad screens. Is the phone recognized in iTunes when you plug it up to a computer?
Score 1
3 Comments:
Don't need to, I tested both screens on another iphone 6 and they worked fine.
by
Sometimes putting the old screen back on, booting the phone up, then powering down, then putting the new screen on fixes it.
I'm sure someone smarter than me can explain why this works, I can only tell you that it does work.
If you put the old LCD back on and it does not work, then you know you have more troubleshooting to do. Please update with results after you try.
by
I really wish I had the old screen. Can't find it anywhere.
by
Add a comment
Add your answer
Peake Nasrallah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 100
