Repair guides and support for your Samsung TV.
2620 Questions View all
Just replaced the color wheel. Now the TV will not turn on.
When pressing the power button. The timer light on the TV turns on then off. You can hear the TV powering up. The lamp is lite in back, but no picture. The lamp then turns off and the standby/temp light and lamp light blink simultaneously. We tried to reset the lamp timer, no changes. Any help would be appreciated. Thank you.
Samsung HL-T5075S
5 Comments
@union422 that is a Samsung model? Do the lights continue to blink or is there a pattern to it?
by
Yes, it is a Samsung model. And yes, the lights continue to blink intermittently, unless the TV is unplugged.
by
Are the fans kicking in?
by
Yes, the fans turn on.
by
The model # is HL-T5075S, not HL-T6075S.
by
Add a comment
1 Answer
Chosen Solution
@union422 "the standby/temp light and lamp light blink simultaneously." is indicating that the lamp cover on rear of the set is not properly shut. Check the microswitch to make sure it closes properly.
Score 3
2 Comments:
Oldturkey03, I can NOT thank you ENOUGH!!!! It worked!!! You just saved me $125. A repair man was coming out today. $125 just to come out and apply to the repair charges. Smh, I would'be been irate to find out this is what I would'be been told. You are TRULY a blessing. If I could tip you I would.
by
You are very welcome. Glad it worked out. BTW welcome to ifixit.
by
Add a comment
Add your answer
Union will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 112
