Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Home Button doesn't work to Wake up Device!
Hi Guys,
I have a problem with an iPhone 6. The screen has been replaced. The Home button is the original.
Now I can no longer wake up with the Home button the device. With the Power button I can wake the device. And as soon as the device is turned on, also works the Home button without problems - except TouchID.
Can someone help me ? Is really broken the Home button? Or the heat shield behind the display?
Add a comment
Try to calibrate the home button:
Push and hold the power button till you see the swipe icon for turn off the device,
the push and hold the power button till the iphone come back to the home screen,
now try to use the home button again!
If still not work, for well understand what could be, backup everything using itunes and restore the software.
Than, use it without restore your backup, as a new ipad and verify the correct or not behave of the home button..
Add a comment
Doesn't work. Any1 other ? Please help me. Can it be the BackShield on the Display ? Or the Homebutton it self ? But why is working, when device was waked up with power button.
1 Comment:
The backshield on the display shouldn't affect the device behave.. On an IPhone 5s i can confirm, I did it for test purpose and the Phone was working as usual.
But have you RESTORE your ios with iTunes downloading again the firmware and let iTunes format the Phone as a new one?
It's a very puzzling question..
For the moment I have no other advice..
Hope someone could give you some other hint!
by
Add a comment
Theres are a few things that could affect the home button to cause it not to work.
- The home button is defective
-Home button ribbon cable got damage during the repair (Check ribbon for signs of tear or rips)
-Back shield was damage during the repair (Check shield for signs of tear or rips on the connections and ribbon)
Add a comment
So I have the same problem except it doesn’t always happen but power button doesn’t work to wake it up either
i replaced the screen, home button works fine except Touch ID, and I also have a 6 plus
1 Comment:
Bobby be more specific, the power button is working fine for turning on or off the device?
The home button work correctly except for the wake up function?
After you replace the screen have you reset your iphone pressing together power and home button till the device restart?
by
Add a comment
Add your answer
golffreiburg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 6,655
