Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
637 Questions View all
camara and iPhone doesn't work
i change the display and when i try the phone the camera doesn´t work so i open it again and try to fixit it. by trying, now the phone doesn't start and the display does´t work
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
1)
Plug it into your computer and open iTunes. Leave it a couple of minutes and come back. If the phone is showing up in iTunes, good. That means it's still alive.
Unplug the battery to turn it off and then reseat the screen connectors. And then plug the battery back in and turn on. If there is no display - you need to replace the screen.
Also, reseat the camera (was it front or back? And if necessary, replace it. Cheap replacements on eBay for this.
If there is no response in iTunes, try power cycling it. Otherwise you may have killed it
Score 1
Add a comment
Add your answer
Matias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 72
