MacBook Pro A1229 shuts down suddenly at 50% Battery capacity left
Hi,
I bought a new battery for my 17¨ MacBook Pro A1229 (Bought Dec. 2007). I followed instructions that came with the battery:
First time use: Let the battery run down to 2% before charging and then charged the battery fully to 100%.
I then proceeded to use my MacBook. At 50% battery charge left, it suddenly shut down completely. I then tried to reload the battery fully to 100% once more, then left the MacBook with it's charger plugged in for 2 hours. When I then used the MacBook, the same happened again; at 50% battery charge left, it shut down.
I the proceeded to reset the SMC and PRAM. This did not fix the problem.
I then proceeded to return the battery to the supplier and received a new identical battery. Followed instructions as listed above; the problem persists - The MacBook Pro shuts down when running on battery at 50%
Add a comment
1 Answer
Most Helpful Answer
How about giving this gem of an App a try: coconutBattery it will show you the condition of your battery and how the system is charging the battery.
Post a screenshot of the main screen when the system shuts down (just after you have restarted the system) so we can see whats up here.
Score 3
1 Comment:
Thanks, will test with CoconutBattery and post screenshot
by
Add a comment
Add your answer
Claus Hopstock will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 313
