Black screen, no fan, or rarely screen flickers
Hi,
I have a Sony Vaio VGN-NR21Z (model PCG-7121M). It was working well for a few years (2009 to 2013).
Then after what may be a little overheating, the screen began to show random flickers (like horizontal lines and sometimes unstable picture). A few days later, the computer wouldn't even boot.
I was about to junk it, and tried again today. The problem is the same : only the power LED lights on. At first, no noise can be heard, no fan noise, no beep.
What I noticed today is that after a while of being powered on (about 5 minutes), the computer's fan starts up, because the CPU is getting hot (I guess).
And what surprised me today is that, while it was hot, I restarted the computer and could ONCE see something appearing on the screen : the VAIO logo with strange squares, and maybe the BIOS lines saying that there is no hard disk (I suppose this was the message, because I removed it, but I'm not sure, of course).
I couldn't reproduce this behavior, unfortunately, and I'm now returned to the black screen.
Given these symptoms, can you help me identify what the problem is? The fact is, this computer has a NVIDIA GT8400M which is known to have the NVIDIA defect. I would like to be sure that this is a NVIDIA GPU failure and not something else.
Thanks!
Update : I opened the notebook and used a hair dryer on the GPU to heat it. To my surprise, the VAIO logo appeared without any distortion, and then the message is «No operating system found» (which is normal because I removed the hard disk). Unfortunalety, when the GPU is cold, then either the screen has flickers, either there is the black screen.
Add a comment
1 Answer
Most Helpful Answer
I would definitely say that it is a graphics card problem given that the fan runs fast (trying to cool the gpu down) and you are having screen problems (gpu not working correctly). Often times what happens with these faulty gpu's is that they overheat and melt the sodder that connects them to the mother board (or they actually damage the mother board) and then they can't transmit data. You could try fixing the problem yourself if you want to take on the problem. Otherwise you might be able to get it fixed somewhere. Good luck!
Score 1
1 Comment:
Thanks for your help! I tried using a hair-dryer for about 1 minute above the GPU, and to my surprise, the VAIO logo appeared (see "update" at the bottom of my message). What I wonder is : are there non-defective NVIDIA GPUs on the market that could fix the problem definitively? What would be good would be to replace the ball-grid array with a socket + a new GPU.
by
Add a comment
Add your answer
Gregoire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 426
