Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Why won't my phone work?
Last night at 10:20, my phone was at 39 percent, so I let it charge overnight. This morning, at 6:13, I pressed the power button, but it didn't respond. When I pressed the power and home button, it still didn't respond. When I pressed the power, home, and volume down button, it asked if I wanted to press the volume up button to download an OSIN or the volume down button to restart my phone. (This might sound irrelevant but it's important.) My brother startled me from behind and I accidentally pressed the volume up button. Then the screen was a blue green and it had a white arrow pointing down with a horizontal line under it. Under the arrow, it said: Downloading.... Do not power off the device.... I couldn't power it off anyway. In the top left corner, it said: "OSIN" in red, some coding in gray, and "Secure Download: Enabled" in blue letters. When it finished downloading, the screen went black again. So I pressed the power, home, and volume down button. When it asked me if I wanted to download it again, I pressed the volume up button so my phone can restart. When I did, it restarted, but then it restarted again and it stopped working.
Add a comment
Most Helpful Answer
Hold the Home + Volume Down + Power button until the screen goes off. NOT any further than that or you'll go on the boot download mode confirmation screen by accident. Then keep the phone plugged in and charging for a bit before turning it on again.
The phone will just boot loop at the white samsung text screen if the battery level is very, very low.
Score 1
Add a comment
Did you ever have any luck? Mine has done pretty much the same thing but also when I plug it in it is always at 0% but then charges up immediately to 100%... Restarts for no reason a lot of times before I can get anywhere at all with it... Ugh
Add a comment
Add your answer
Kate Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 305
