Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Questions View all
Question Closed
My tablet only charges while it's off.
I haven't been able to figure out the issue but I assume now it's software and not hardware. My tablet died one night while on a charging dock.
I set it to charge, then I realized that while it's on, the little charge icon shows it's charging even when it's disconnected. However, it doesn't charge at all. I tried using both the charging dock and charging port. I tried downloading 4 different apps to check the voltage, and they all say there's a charge. Additionally, they read that the battery is fine. I tried a different charger and no luck. However, if I turn off the tablet, it'll charge like normal.
I reset the tablet already. I replaced the charging port. Any ideas?
Add a comment
1 Answer
Most Helpful Answer
I had this exact issue. My fix was to replace the battery with a battery from another used tablet. The device will still say that it is charging when it is unplugged at 100% but will stop shortly after. The device does charge now though.
Score 1
1 Comment:
Thanks so much. I will try that.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 999
