Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426 Questions View all
How to fix error on my camara, error code 0xA00F424A(0xC00D3704)
Error code 0xA00F424A(0xC00D3704
Score 33
5 Comments
please restart the computer then your camera will do the job
by
ty very kind of you
by
no use of restarting: i have the same problem and i tried it but it doesn't work.
by
Mi teléfono Microsoft Lumia 950 tenia ese problema y lo corregí cambiando la cámara frontal de otro teléfono dañado de la pantalla, fue la única forma.
by
This erro comes as CAM is already in progress in diff APPS.
check the processors in the task manager ,if any skype and any cam replated applications are running then END TASK and check the camera hope it will start working
by
Add a comment
Most Helpful Answer
1.) the camera is currently being used in another app
2.) your camera is updating
3.) shutdown and relog into your device
4.) exit out of all tabs and/or refresh
5.) reinstall your camera app
6.) don't use your camera at this time and try later
was this helpful? thank you for reading and i hope this was helpful.
Score 7
2 Comments:
Nothing works no matter what I do, I reset my phone to factory but its messed up still, :/ I may just take it to a shop
by
how to close the othar app
by
Add a comment
another one solutions for switch camera front to rear, press switch button and minimize the app and again go to app.. hope its work.... Thanks
Score 4
4 Comments:
I did it and it worked. Thanks
by
It worked for me too . Thanks
by
works for me. thanks
by
Man your a genius, ive been trying to fix this issue for years an yours is the only way to fix it lot of thanks to you
by
Add a comment
Each time I try to use my camera for front facing it says "something went wrong"
Score 2
Add a comment
ad 1 - no, i;ve got clean install
ad 2 - no, I've got last updates installed (error occured even after clean factory reset)
ad 3 - no effect
ad 4 - no effect
ad 5 - I can't uninstall factory installed CAMERA app (error occurs on other apps from store, too)
ad 6 - great advice - I'll try on my next phone :)
Score 1
Add a comment
how do you fix it then
Score 1
Add a comment
Every time I tried to go to camera. It goes out and back to home sceen
1 Comment:
My front camera is not working
by
Add a comment
Problem solved by service - changing mainboard was needed :( Nothing about software.
Add a comment
I have a Nokia Lumia 830 cell phone running Windows 10 Mobile Version: 1607, build 1480, firmware: 02040.00021.15235.53001, it has been a perfect device until now. Took a normal photo, tried to send via messaging, "Can't Send", tried sending a couple of times. Went to take another photo, with message "Something went wrong" If you need it, here's the error code: 0xC00D3704. Also noticed the flashlight app no longer works. Can't do anything with the camera app. I'm guessing this is a driver problem but have no way to correct, update or reset. HELP
Add a comment
1 Comment:
by
Add a comment
This error comes as CAM is already in progress in different APPS.
check the processors in the task manager ,if any skype and any cam related applications are running then END TASK and check the camera hope it will start working
Add a comment
It looks like another app is using the camera already
Add a comment
Camera not functioning
Why
Add a comment
please guys help me I have unrro camera
Add a comment
Add your answer
nintokeseinpni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 31,109
