Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
I have 3 dead iPhone 6's nearly perfect physical condition
Over the last month I have 3 iPhone 6's come into my shop all with the same complaint that it won't turn on.
All three of these phones look like they are fresh out of the box, screen, chassis and internals are pristine but they are dead. 2 of the 3 customers say the phone was dropped previous to issue but they we in a good protective case.
I have tried to change the charging dock and battery, neither of which have made any difference.
Has anybody had any luck in a situation like this?
Add a comment
Most Helpful Answer
Try this ....
Press the Power Button for 10 seconds. Release the Power Button and hold the Home button for another 10 seconds.
Now you connect your iPhone to iTunes, which should recognize the phone in recovery mode. Now you can try to restore it.
Score 1
Add a comment
Already tried to push the power and home button at the same time ?
It could be a hardware problem..
Already tried changing the battery ? Try with a CHARGED battery maybe it's the charging IC.
Let me know how it turned out !
Louis
3 Comments:
Black screen, no signs of power at all, so I'm not sure how pressing the power button and home button at the same time will help.
Replaced both the dock connector and battery, neither helped.
by
Found a solution?
Let me know.
by
Solution is to replace one or more component chips on the logic board. Preferably power management / power ic chip first. This requires a lot of skill to do so I'd take it to someone that is experienced in doing this.
Sadly this is a common issue on the iPhone 6 / 6 + when the phone is dropped. It's a 50/50 chance that it will work not. This is sometimes not repairable.
So does the phone heat up at all near the camera area or on the logic board?
by
Add a comment
There is a lot of info regarding bad/defective NAND flash chips with the 64GB AND 128GB MODELS.
I haven't been able to find a solution. Check with Apple support.
Add a comment
Add your answer
Joe Waldherr will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 124
