Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Replaced charging port now won't turn on.
I just replaced a charging port in a 6 plus and I plugged it in and registered it was charging (the phone was dead). It never turned on though and now the screen won't light up. I take it the charging port is bad?
Score -1
1 Comment
Did you put the screws in the right spots? Look at step 9. iPhone 6 Plus Screen Replacement
by
Add a comment
1 Answer
Chosen Solution
Make sure the screws are in the right location. Did you test the charging port before you installed it? I always test the charging ports before installing them because they can be defective. Open the phone up, leaving the screen attached, disconnect the old connector for the charing port and Just connect the connector to the motherboard with the charging parts laying on the right side of the frame of the phone, then try a charging cable to see if phone is charing. If it charges then install the charging port, but think you have defective port.
Add a comment
Add your answer
Troy wells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 679
