A bluetooth and wifi-capable AM/FM radio speaker.
6 Questions View all
Question Closed
How do I disassemble the unit?
The device only has one screw visible, found under the antenna. Unscrewing this does not open up anything to take the face off the unit. There are also no visible pieces that can come off or anything. How do you go about actually disassembling the unit?
Add a comment
1 Answer
Chosen Solution
You may have to unclip plastic clips from around. Use your fingernail to get a gap in the device's two halves, then stick a metal spudger in about 1 CM. Go around the unit, using a twisting motion. Be careful of any wires that may get caught on the spudger.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 74
