Dell Inspiron 15 3531 won't support new universal replacement charger
Had to replace battery charger for Dell Inspiron 3531. Bought one from Best Buy (was a universal type, with different adapters), plugged it in, and the laptop would not support it, wouldn't charge. I can't find an original Dell charger online, just more replacements. If I buy a replacement OEM type, will it work, or will it not be supported too?? I don't want to waste time and money ordering chargers that will give me the "not supported" message.
Score -1
4 Comments
@volzster what are the specs of your universal charger?
by
I returned it, so I'm not sure, other than I do know it was 65w, which is what is required for the laptop.
by
@oldturkey03 , what I'm basically wondering is will a non-Dell made charger, that is an OEM replacement, work. I know with some electronics, they are made to only accept their manufacturers parts/accessories.
I'm assuming that because the one I purchased was a universal charger with interchangeable port adapters , that it may have been the issue, because it was made for several types of laptops instead of just the Dell.
by
The correct specs can be taken from your old charger. It will have a sticker on the bottom stating rated output voltage and current, as well as the DC plug polarity.
by
Add a comment
1 Answer
Chosen Solution
Hi @volzster
Here are the specifications for the adapter for your laptop, from the Dell specifications document. http://downloads.dell.com/manuals/all-pr...
Ensure that the adapter you get has exactly the same values as is highlighted below and it should work. The information will be printed on the adapter itself. Also ensure that it has the correct DC plug connector compatible with your laptop socket.
Power Adapter
Type 65 W
Input voltage 100 VAC–240 VAC
Input frequency 50 Hz–60 Hz
Input current 1.50 A/1.60 A/1.70 A/2.50 A
Output current 3.34 A
Rated output voltage 19.50 VDC
Temperature range: Operating 0°C to 40°C (32°F to 104°F)
Storage –40°C to 70°C (–40°F to 158°F)
Score 1
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 857
