Screen is dim won't brighten
So I tried installing an led mod on my iPhone 6. The one that makes the apple logo on the back light up. Now my screen won't brighten. Tried another screen still dim.
Have you removed the modification? Certain modifications that draw power from the device using certain solder points will affect other components.
Yes I have still dim
There's a possibility that you've damaged whatever component (or even multiple components) you applied the mod to. Some moders don't realize it, but damage to one part (the logic board) may not be limited to just that one part, and it can carry out damage to other components as well (screen, backlight, battery, etc.). You may want to try each of those components one at a time.
So would you recommend that I buy a new screen
Start with that, and if it doesn't work, then move on to logic board, then battery, then antenna, in that order.
If you continue to have problems, start another thread, but you know what to do now, so please close this thread in order to clear up the number of "unanswered" questions in the forum by marking an answer as correct. Thanks.
Sounds like a posable backlight filter problem. This is a board level repair that requires specialized repair tools.
i do not recommend these apple logo light mods . i had one myself on iPhone 6 but numerous issues and a likely chance you will damage your screen (its just not worth risking)
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,399
Yes I have and still dim
by Sergio
