Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Questions View all
Question Closed
Half screen touch doesn't work and picture is washed out
My son's iPad mini 2 was working fine until a trip to the beach. I can not get an honest answer as to whether he dropped it or got it wet. But it was probably one or the other. Now his touch screen only works on the top half. So to use it, he has to continuously rotate the screen so where he wants to touch is on that half. It does work this way. Also, the screen now has a very washed out look to it. Everything can be seen but just real pale looking. I am pretty handy at following directions. Doe's anyone have any idea what I need to do? We had just replaced his old mini (that was out of warranty) about 3 months earlier. So this one has no warranty on it.
Thank you in advance!!
Add a comment
1 Answer
hello probably water has damaged some iPad's component.
the touch screen does not cost you much if you can replace it by following the guides iFixit.
you can groped to open it and wash the parts where it is visible traces of water, but until the device can not be opened to determine whether the problem depends on the touch screen connector or from some oxidation caused by water on the motherboard. you should open and investigate,but because it works in almost all its parts there are high hopes .
good luck
Add a comment
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 3
All Time: 133
