The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Questions View all
Dryer Will Not Start; No Error Codes, All Lights Normally
My Kenmore HE3 Electric Dryer (Model 110-82836100) suddenly stopped working. Everything appears normal but when you press the start button all you hear is a beep and a loud click near the control module. I have checked the thermal fuse and thermistor and both are within tolerance. I have checked the 220 power and the machine is receiving the normal voltage. I have run the machine through the test diagnostics and there are no error codes and all of the LED lights are working as indicated. The door switch tests good as does the moisture sensor. I have not tested the belt switch nor replaced the electronic circuit board. Any suggestions on how I could the circuit board before replacing it? Also, should I test all of the other switches and motor before replacing the circuit board?
Score 1
Add a comment
Chosen Solution
I just discovered the answer. The drum belt is broken. So the belt switch is what is causing the machine to behave as indicated. I will provide an updated answer after I replace the belt.
1 Comment:
alway love to hear back when things get fixed and we don't even have to help . Congrats
by
Add a comment
This is the follow up answer. I replaced the drum belt and everything is now working normally. AppliancePartsPros.com has a nice video on how to replace the belt.
Add a comment
Add your answer
Dean Halstead will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 822
