Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
After replacing broken screen I have the white screen of death.
I bought 3 different pieces from "WirelessFinest" on Amazon (I don't care how low their prices are, DO NOT buy from them!!!).
First I bought only the screen and I successfully removed the broken glass and replaced it but they sent me the part for a 3G instead.
So now that I attached it to my frame I have to buy the whole frame plus screen. When I received it I installed it but the earpiece sounded like it was blown. I tried many times to put the ribbon cables in again and I also removed the cable from the earpiece from my original frame all to no avail.
I ordered a new frame plus screen again and when I first installed it the screen worked fine but again the speaker sound was too low, I could barely hear anything. So I tried reinstalling the ribbons a few times and checking it and I got the white screen of death then it went black but the display still worked.
I found out how to reformat it so I did that and now the white screen of death is back and no amount of hard resetting it is working. It turns off and it won't come back on until I hold down the power button. Please HELP!!!
Score 1
Add a comment
1 Answer
Chosen Solution
i'd try opening it back up (after you press power button and slide to power off) and reconnecting leads 1-3. lcd is no 1 and it pops up easily when you close the front panel, just check it as your closing.
Score 1
Add a comment
Add your answer
kittyfeliz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,053
