Fix Your Stuff
Right to Repair
Parts & Tools
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4961 Questions View all
iPhone doesn't charge after drop down
Hello everyone!
I dropped down my iPhone 6. The phone had only cracked screen, so I was happy with result because the phone still worked. But! Before I came home, the phone was out of battery, so I plugged it in to the charge but nothing happened after 24 hours in charge. DEAD.
I tried to change battery but still nothing.
When I tried to measure the battery after 24 hours in charge, it had 0V.
I tried to measure input voltage on motherboard and it had only 0.8V and I think that is a problem.
It looks like bad charging dock or something like that. What do you think?
Thank you!
Score 1
Comments:
Thank you guys. I hope that will be the right solution.
by
Add a comment
Chosen Solution
Definitely the charging port.
Score 2
Add a comment
If the lightning cable doesn't go in fully into the charging port then you'll need to clear it of debris inside the charging port. Something like a toothpick or equivalent will work for cleaning it out.
Score 2
Comments:
I think that the problem will be inside charging port. I will buy new one.
by
Add a comment
Add your answer
Milan Rada will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 132
