Repair guides and support for your Samsung TV.
2620 Questions View all
Shows the PC desktop but "No SIgnal" won't go away either
My TV always shows the HDMI (1or2) resolution, refresh rate at the top left and the big "No SIgnal" box when PC is connected. It does show the desktop too.
If there wasn't a previous input on the HDMI I can't select it when I plug the computer in. Even though it displays what it's supposed to the TV "won't recognize" there is something hooked up.
TV is Samsung model un65fh6001fxza
I unplugged it for 10 minutes and hooked it back up. - no change
Tried multiple resolutions and refresh rates - no luck w/ any of them
Tried changing input name to DVI PC and PC.
I'll update the firmware as soon as I can find one of my USB drives.
Score -1
Add a comment
1 Answer
Check HDMI port on TV very closely - it might be some dirt in the connector itself - use a toothpick or very little brush and try to clean it (compressed air helps as well).
Next step is trying with new HDMI cable (some of them are even device sensitive - check picture on connector computer/TV out)
Check HDMI connector on computer side as well
Usually this kind of trouble happened when cable connector is not deep enough in HDMI socket.
Add a comment
Add your answer
DrTachyon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 881
