replaced logic board, no power
I have replaced the logic board and tried to power on, no power.
You may want to double check all the wires are in good condition and connected. Also make sure no ribbon cables are damaged. If none of this worked is it charged? Is the block and the wire in good working order? Try charging it with another cable and/or block.
Thanks I will try that, I think I put the cable from the screen glass on the bottom instead of actually connecting it not thinking, I have been thinking that for a white!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 59
