Informative guides for home coffee and espresso machines.
1489 Questions View all
Wasser wird nicht heiß? Water does not get hot?
Die Kaffeemaschine Senseo geht an nur macht sie das Wasser nicht heiß sodass man den Kaffee nicht aufbruehen kann!
The Senseo turns on but does not heat the water up to brew the coffee.
1 Comment
Dieter Haarer, do you have a model number for your Senseo?
by
Add a comment
1 Answer
Chosen Solution
Dieter Haarer the boiler in the coffeemaker could be protected by some fuses. Depending on the model of your Senseo, the location will vary. You'll have to disassemble your coffeemaker to take a look at it. You also want to check the temperature sensor to make sure it functions. Post plenty of images when you disassemble your coffeemaker and post those with your original question. Use this guide for that. That will allow us to see what you see.
Score 2
Add a comment
Add your answer
Dieter Haarer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 326
