My speaker doesn't seem to charge
I am having trouble with charging my speaker. I have plugged it into multiple different outlets with different USB cables but it won't seem to charge. Any ideas?
Unfortunately, it seems like you may have an internal issue with the speaker. The micro-USB port may be malfunctioning, or the battery may be bad. Either way, you may have to do some work inside your speaker to fix your problem. Please refer to the replacement guides to help you.
Actually if you take the front of the speaker off there are big holes you can use a thin screw driver. Find the box within you will find a charging port, a power supply charging port inside the speaker. Use a thin thin flathead screwdriver and bend the black piece within the inside of the charging port USB HOUSING . PRY Bend it down a bit. Then PRY bend the OUTSIDE bottom of the USB charger port casing UPWARDD with the flathead SCREWDRIVER so that it makes a tighter connection to the charging cable tip. You can use needle nose pliers on the charging port to clamp it tightly to the computer chip that it is fastened to. Plug the charging port in while you have it apart. If the light blinks it means you have to reattach the long white power Sata cable which I haven't mentioned yet. The Sata connector cable clamp that holds it in can snap so don't pry it open there are two push pins on the sides which release a Sata cable. Google it. sata cable disconnect. tighten USB fitting
Hi @bendatbootyover ,
I've restored as many of your deleted answers/comments as possible and then deleted them as duplicates to avoid confusion. This will restore most of your lost rep. points. I can't do this with some that were deleted but will inform the admin to see what they can do.
Sometimes the spam iRobot gets it wrong and deletes things. I don't know why.
Moderator.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,062
