flash,rear and front camera not working
flash,rear and front camera not working after sostitution screen
Sounds like possible long screw damage. Is it possible you mixed up the screws during the repair? If so, you will have to have the board repaired by an experienced board level technician.
@peppe , if you wanted to have the long screw damage repaired, there’s a link on my profile to a board repair website that catalogues very trusted and highly recommended board level techs around the world. You can surely find someone there to send the device to.
Cheers
thanks Well I think the hypothesis of long screw is possible, as the phone has been opened and closed again hurt
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 246
7 Comments
I also replaced the cameras but still do not work
by Peppe
do you have the flash enabled in the settings ?
and does the 6 have the front face flash or is it not the 6s?
by Jimfixer
hello jim ..... the torch is active and I replaced the 2 cameras but still do not work
by Peppe
Front speaker is working? Ear speaker? Proxy sensor (display goes black when you cover the front cam area or put the phone to your ear)?
by Rany
What he means by display goes black, he means during calls, does the iPhone display go black when you put your phone near your area? If yes, that means the proximity sensor is working. If any one of the above mentioned by Rany is not working, then you may have a damaged flex cable or component which is assembled behind the screen.
by Ben
Show 2 more comments
