The Canon EOS 300D is a 6.3-megapixel entry-level digital single-lens reflex camera.
34 Questions View all
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Add a comment
Chosen Solution
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
Add a comment
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Add a comment
This can also be caused by a defective/broken CF door switch
Add a comment
Could it be for any other situations, as I have done all checks and keep the problem.
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,644
