Can I use paper with extra length (327mm/1000mm for example)
Hello everyone
I m the lucky owner of an epson L1300 and I would like to know how can i print on extra long paper (327mm/ 1000mm) is it possible ? Or is it too long ? i m not talking about the width as the epson l1300 takes A3+ my question strictly consern the maximum length i can use
Thank you in advance
Add a comment
1 Answer
Chosen Solution
Pull up the printer's settings/properties window. You can select paper size from a list, but you can almost certainly set a custom paper size. Width is of course limited by the width of the printer, but you can try setting the height/length to whatever value you'd like to use and see if the printer driver will accept it.
Score 3
Add a comment
Add your answer
pvpclement will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 111
