2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
69 Questions View all
Can I use its 802.11ac AirPort Card on my RMBP 13 (early2013)?
Is late2013's 802.11ac airport card fully compatible with early2013?
I have a 802.11ac WI-FI, and I'd like to use torrent faster.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Well yes & no here :-(
Yes you can upgrade your AirPort card to a Broadcom BCM94360CS2AX.
But you will find the amount of gain will be limited as the antennas in your system are not matched and the Internet connection you have will also limit you. If on the other hand you had a local server you are more likely notice faster access to it.
Score 1
Add a comment
Add your answer
jejaforce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
