Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Bootloop after screen replacement.
After replacing LCD/Digitizer and putting phone back together I started up the phone. Black apple logo over a white back drop appeared, the screen blinked and went to the low battery image. (picture of empty battery with just a red sliver). Seeing how the phone hasn't been used in a few months I assumed that the battery was probably just dead. I plugged it into the wall charger and as it was charging the phone would loop from low battery to boot logo to illuminated blank screen and repeat.
I let it charge overnight with no change. So I tried to put it into DFU mode. There was no "connect to itunes" image. I plugged it into the comp anyway and itunes detects it in DFU. I download and restored iphone but near the end of the installation of the new ios I get an error code stating that the iphone could not be updated.
I checked all the connections/screws for the fourth time. Inspected ribbon cables, home button etc. I purchased a new battery and installed it with no change... Am I missing something here?
TL;DR
New screen - didnt work
DFU iTunes - got error
Computer connects to phone
Checked all screws/cables
Replaced battery - still doesn't work
Add a comment
Chosen Solution
It doesn't sound like you've damaged the logic board. Otherwise you wouldn't even get detected in dfu. What error does it give you? That's the important part
Score 2
2 Comments:
I got error 4013, as im having the same issue
by
Try checking your cord, and try a different laptop. You could argue the lightning dock to be the issue. Also one thing you could try, and I would back the phone up first, is resetting all settings. Then try the restore again. The last one could prove tricky, if the phone won't boot up
by
Add a comment
Did you make sure that all the screws for the LCD assembly shield were put in the right place? If you mess up the screws(You can see this in the guide) you will destroy traces on your motherboard.
Add a comment
Add your answer
Charles Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 432
