1979-1981 Camaro: How do I fix the steering?
The steering on my 1981 camaro is squeaking and is getting hard to turn. I'm wondering what can be the cause of it and how can it get fixed.
I would say it is your power steering pump. Check fluid level and with the engine running have someone turn the wheel slowly and see if the fluid is circulating. If fluid is gone then you have a hole in one of the lines or in the pump it's self. Not sure if it has rack and pinion steering but if it does that could also be your problem.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 137
