The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Questions View all
SSD Chassis for Optical Drive slot?
As question title eludes to, is there a Chassis that fits this CD drive slot? I have a samsung 250g ssd that I'd like to use for my laptop but dont really know what Chassis to get.
Thanks!
Score -1
Add a comment
Chosen Solution
this is am extremely thin chassis 9.5mm try something more like this,
http://www.ebay.ca/itm/New-2nd-2-5-SATA-...
hope this helps
Score 3
Add a comment
Most Helpful Answer
I reviewed the E-Manual for your model and there was no information listed about the size of the optical drive.
Upon doing a search on the Asus eStore using the terms internal dvd, of the several optical drives listed, each were 12.7mm.
I would recommend contacting Asus directly at verify this is the size of your optical drive. If this is the case, you may be able to order through them directly.
A search on Amazon using the terms 12.7mm ssd dvd displays multiple results that would be compatible, but I recommend verifying the dimensions before ordering.
Score 4
Add a comment
Add your answer
Clint Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 557
