CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
421 Questions View all
My iPhone keeps dying.
Since a few days my iPhone 4 cdma just all of the sudden turns off and won't turn on until you plug it in to a charger. It boots immediately and is at the percentage when ever it turned off which is often like 90 percent. Holding the home and power button also doesn't work. I already tried replacing the battery. Another way is to unplug the battery and plug it back in then it will boot without having to charge it. I really don't know how this could be. No water damage by the way.
Add a comment
1 Answer
Chosen Solution
I would try restoring factory defaults on your iPhone, otherwise you may have an issue with your logic board.
Add a comment
Add your answer
Kilian Schwarz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 112
